NEMA-17 MOTOR STRONGLY BEEPING November 06, 2016 01:53PM |
Re: NEMA-17 MOTOR STRONGLY BEEPING November 06, 2016 05:06PM |
Re: NEMA-17 MOTOR STRONGLY BEEPING November 07, 2016 03:20PM |
// Use "Z Safe Homing" to avoid homing with a Z probe outside the bed area. // // With this feature enabled: // // - Allow Z homing only after X and Y homing AND stepper drivers still enabled. // - If stepper drivers time out, it will need X and Y homing again before Z homing. // - Move the Z probe (or nozzle) to a defined XY point before Z Homing when homing all axes (G28). // - Prevent Z homing when the Z probe is outside bed area. //#define Z_SAFE_HOMING #if ENABLED(Z_SAFE_HOMING) #define Z_SAFE_HOMING_X_POINT ((X_MIN_POS + X_MAX_POS) / 2) // X point for Z homing when homing all axis (G28). #define Z_SAFE_HOMING_Y_POINT ((Y_MIN_POS + Y_MAX_POS) / 2) // Y point for Z homing when homing all axis (G28). #endif // Homing speeds (mm/m) #define HOMING_FEEDRATE_XY (50*60) #define HOMING_FEEDRATE_Z (4*60) // // MOVEMENT SETTINGS // @section motion // // default settings #define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,4000,500} // default steps per unit for Ultimaker #define DEFAULT_MAX_FEEDRATE {300, 300, 35, 25} // (mm/sec) #define DEFAULT_MAX_ACCELERATION {3000,3000,200,10000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot. #define DEFAULT_ACCELERATION 3000 // X, Y, Z and E acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 3000 // E acceleration in mm/s^2 for retracts #define DEFAULT_TRAVEL_ACCELERATION 3000 // X, Y, Z acceleration in mm/s^2 for travel (non printing) moves
Re: NEMA-17 MOTOR STRONGLY BEEPING November 07, 2016 06:13PM |
Re: NEMA-17 MOTOR STRONGLY BEEPING November 07, 2016 09:02PM |
Re: NEMA-17 MOTOR STRONGLY BEEPING November 07, 2016 11:34PM |
Re: NEMA-17 MOTOR STRONGLY BEEPING November 08, 2016 12:41PM |
Re: NEMA-17 MOTOR STRONGLY BEEPING November 12, 2016 01:09PM |
