NEMA-17 MOTOR STRONGLY BEEPING November 06, 2016 01:53PM |
Re: NEMA-17 MOTOR STRONGLY BEEPING November 06, 2016 05:06PM |
Re: NEMA-17 MOTOR STRONGLY BEEPING November 07, 2016 03:20PM |
// Use "Z Safe Homing" to avoid homing with a Z probe outside the bed area.
// With this feature enabled:
// - Allow Z homing only after X and Y homing AND stepper drivers still enabled.
// - If stepper drivers time out, it will need X and Y homing again before Z homing.
// - Move the Z probe (or nozzle) to a defined XY point before Z Homing when homing all axes (G28).
// - Prevent Z homing when the Z probe is outside bed area.
//#define Z_SAFE_HOMING
#if ENABLED(Z_SAFE_HOMING)
#define Z_SAFE_HOMING_X_POINT ((X_MIN_POS + X_MAX_POS) / 2) // X point for Z homing when homing all axis (G28).
#define Z_SAFE_HOMING_Y_POINT ((Y_MIN_POS + Y_MAX_POS) / 2) // Y point for Z homing when homing all axis (G28).
#endif
// Homing speeds (mm/m)
#define HOMING_FEEDRATE_XY (50*60)
#define HOMING_FEEDRATE_Z (4*60)
// MOVEMENT SETTINGS
// @section motion
// default settings
#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,4000,500} // default steps per unit for Ultimaker
#define DEFAULT_MAX_FEEDRATE {300, 300, 35, 25} // (mm/sec)
#define DEFAULT_MAX_ACCELERATION {3000,3000,200,10000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot.
#define DEFAULT_ACCELERATION 3000 // X, Y, Z and E acceleration in mm/s^2 for printing moves
#define DEFAULT_RETRACT_ACCELERATION 3000 // E acceleration in mm/s^2 for retracts
#define DEFAULT_TRAVEL_ACCELERATION 3000 // X, Y, Z acceleration in mm/s^2 for travel (non printing) moves
Re: NEMA-17 MOTOR STRONGLY BEEPING November 07, 2016 06:13PM |
Re: NEMA-17 MOTOR STRONGLY BEEPING November 07, 2016 09:02PM |
Re: NEMA-17 MOTOR STRONGLY BEEPING November 07, 2016 11:34PM |
Re: NEMA-17 MOTOR STRONGLY BEEPING November 08, 2016 12:41PM |
Re: NEMA-17 MOTOR STRONGLY BEEPING November 12, 2016 01:09PM |
