Deburring P3 Steel Parts
November 13, 2016 03:23PM
Any tips or tricks here as it seems like a big tedious job..
Re: Deburring P3 Steel Parts
November 14, 2016 03:49AM
wire wheel in a drill? I strongly recommend you wear protective gloves.
November 17, 2016 09:31AM
I had my p3 steel frame laser cut using nitrogen. The parts came out perfect no burrs at all.
Just painted and assembled.
So anyone who is having a p3 steel cut make they sure the use nitrogen, it has a major advantage in getting clean cut parts.
November 18, 2016 06:11AM
I had two burrs on my P3steel frame from Orballo Printing and used a Dremel with sanding disk to remove them.
