Changing extruder Geeetech Prusa I3 Pro B
Posted by lolo_aguirre
November 17, 2016 02:06PM
I need to change the extruder hotend of my Prusa I3 Pro B with a GT2560 card and Marlin firmware. I couldn't found an alternative in Geeetech page, so I tried to buy one in Amazon for the Mk8 extruder:
[www.amazon.es]
The thermistor connector is not the same, but I have checked with a tester that it can be connected to the board. When I turn on the printer, it says that the extruder it's at room temperature, but when I heat up to 180ยบ it heats extruder to a much bigger temperature, it seems as is the thermistor don't measure temperature correctly. How can adjust it? Thanks
Edited 1 time(s). Last edit at 11/17/2016 02:06PM by lolo_aguirre.
Re: Changing extruder Geeetech Prusa I3 Pro B
November 17, 2016 05:48PM
If it is a different thermistor (the thing that measures the temperature) you will probably have to change the type in the firmware.
November 17, 2016 05:49PM
What type of thermistor is it? That's the key, once you locate the thermistor type you can adjust Marlin to reflect that type in the configuration.h file.
