Can't get back to Z offset after G29 December 18, 2016 04:33PM |
Re: Can't get back to Z offset after G29 December 19, 2016 03:41PM |
Re: Can't get back to Z offset after G29 December 20, 2016 06:11AM |
Re: Can't get back to Z offset after G29 December 20, 2016 01:07PM |
o_lampe
Did you check the functionality of the BLTouch? To me it looks like the trigger signal is not stable or got misread ( ground-issues, noise or insufficient voltage level)
Sidenote: why do you have to ABL your FT5 every time? It's not a delta and looks rock solid
The fact that the common denominator is an even 5 mm is the clue here and most certainly is program related. I plan to download and compile from scratch the company's program in case my copy got screwed up somehow. Also, I'd like to try the RC8 version but I need to use the newer version of Arduino; however, it won't compile the RC3 marlin I've been running in my FT 202 i3 for well over a year. The darn programs (Arduinoe) aren't backwards compatible. grrrrrrrrrrrr. And you can't have two versions on the same computer. |
Re: Can't get back to Z offset after G29 December 21, 2016 11:46AM |
Re: Can't get back to Z offset after G29 December 22, 2016 06:26AM |
