Heatbed issue January 07, 2017 02:28PM |
Re: Heatbed issue January 07, 2017 07:43PM |
Re: Heatbed issue January 08, 2017 08:11PM |
I'm not sure what you mean when you said that you hard wired the bed with board current and when you put the negative on the wire got real hot. Where were you feeding the bed from? Also you shouldn't be trying to make connections carrying this sort of current with the power on. They don't like it.
Bed heater connections need the wire ends properly terminated and need to be securely connected. If not they can arc and melt the connections and wire insulation.
Re: Heatbed issue January 09, 2017 06:31AM |
Re: Heatbed issue January 09, 2017 07:21AM |
Re: Heatbed issue January 09, 2017 04:23PM |
Re: Heatbed issue January 09, 2017 06:19PM |
Re: Heatbed issue January 09, 2017 08:06PM |
Re: Heatbed issue January 10, 2017 06:40AM |
Re: Heatbed issue January 10, 2017 08:31AM |
Re: Heatbed issue January 10, 2017 12:24PM |
Re: Heatbed issue January 10, 2017 02:50PM |
Re: Heatbed issue January 10, 2017 06:13PM |
Re: Heatbed issue January 10, 2017 07:50PM |
Re: Heatbed issue January 10, 2017 08:11PM |
Re: Heatbed issue January 13, 2017 09:36PM |
Re: Heatbed issue January 14, 2017 05:15AM |
Re: Heatbed issue January 14, 2017 08:14AM |
Re: Heatbed issue January 14, 2017 03:04PM |
Re: Heatbed issue January 15, 2017 09:00AM |
