No Power to Heatbed on RAMPS
Posted by Staysail
January 09, 2017 12:46PM
Building a RepRapGuru from a kit received at Christmas. The heat bed is not heating. Voltmeter on D9 terminals shows 0 after manually switching on the heat bed in Repetier. Guidance on where to go next with troubleshooting would be appreciated.
Re: No Power to Heatbed on RAMPS
January 09, 2017 03:40PM
Did you wire the powersupply to all four connector of the green plug?
The heated bed is usually connected to D8!
D9 is for a cooling fan, D10 for the extruder.
January 10, 2017 12:22AM
I was mistaken, heated bed is connected to D8. Four wires from power supply go to the green plug. Both pairs run 11.9v from the Power Supply to the green plug and are in the same order (red black, red black) as on Step 42 in the build manual.
January 10, 2017 02:13AM
Does the controller see a heated bed temperature. It will not try to heat up the bed if if can't see some sort of a bed temperature. Safety feature.
January 10, 2017 08:58AM
Repetier doesn't show a temperature for heated bed. Heated bed wires are connected to T1. It is oriented with the black wire towards T2 and the red wire towards T0.
January 10, 2017 12:15PM
When not heating the extruder and bed should both show ambient temperature. If they are not doing this then you probably have a thermistor connection problem.
January 13, 2017 03:26PM
Thermistor on extruder works fine. Verified the RAMPS board is okay by temporarily plugging extruder thermistor into T1 then powering up. Repetier showed ambient temp for "heated bed". Verified continuity of heated bed thermistor wires (solder point on heated bed to plug that goes onto the RAMPS). Soldered connections on heated bed look fine. Problem seems to be narrowed down to thermistor on heated bed. Are there additional troubleshooting steps that can be done? Next steps?
January 13, 2017 06:47PM
Is this a bead type thermister that is taped to the underside of the bed, or is it a chip type that is soldered to bed contacts ?
January 13, 2017 07:09PM
You have set the temperature sensor type in your configuration.h ?
ie
#define TEMP_SENSOR_BED
is set to something other than 0?
January 13, 2017 09:36PM
Q1
It must be a chip type thermistor as the wires are soldered directly to the bed and I don't see anything taped to the heated bed. It is attached to P2 on the heated bed.
Q2
From the config.h file...
#define TEMP_SENSOR_BED 6 <== should I set this to 0 (zero) then push it to the Arduino?
January 14, 2017 03:21AM
When I first got my Anet A8 I got a thermistor failure showing for the bed. I went over and over the wiring to no result until eventually (I should have thought of it sooner) I checked the thermistor resistance at its connection on the bed edge and got open circuit. Reading directly across the thermistor itself gave the required 100k. I then took readings from the bed edge connections to the thermistor and found that one of the extremely fine print tracks read open circuit. Examination of the track with a powerfull magnifying glass showed up a hairline thickness break in the track. A manufacturing fault since it was covered with the varnish coating.
