Viable or Existing XAxis motor mount idea? February 10, 2017 01:04AM |
Re: Viable or Existing XAxis motor mount idea? February 10, 2017 02:00AM |
Re: Viable or Existing XAxis motor mount idea? February 10, 2017 12:56PM |
RGN01
Have a look at my upgrade parts for my Prusa i3 Steel inspired printer [www.thingiverse.com]
The X-motor sits on a carriage on extended X bars.
[attachment 90316 e646c6e8501fee000b57035a9cd374ed_preview_featured1.jpg]
[attachment 90314 3ace77781742e02607e598c9f18f883f_preview_featured1.jpg]
Richard
Re: Viable or Existing XAxis motor mount idea? February 12, 2017 09:57AM |
Re: Viable or Existing XAxis motor mount idea? February 13, 2017 07:56AM |
Re: Viable or Existing XAxis motor mount idea? February 14, 2017 01:10AM |
Re: Viable or Existing XAxis motor mount idea? February 14, 2017 08:05AM |
Re: Viable or Existing XAxis motor mount idea? February 14, 2017 03:21PM |
MCcarman
To try and be clearer, using RGN01s picture.
If the X guide rods went straight through the Z carriage then his springs will push the Z carriage to the right and it could move on the rods. The belt tension will pull the other z carriage to the left. you probably get bowed "vertical" sides.
If the X guide rods finish in the Z carriage and the motor is mounted on separate rods the Z carriage can't slide and you only need to stop the other z carriage moving.
The springs are only there to provide the tension in the belts. Belt tension = spring stiffness x spring compression distance.
