Prusa i3 - Hot End PID Autotune Fail - Timeout March 01, 2017 07:46PM |
Re: Prusa i3 - Hot End PID Autotune Fail - Timeout March 02, 2017 02:26AM |
Re: Prusa i3 - Hot End PID Autotune Fail - Timeout March 02, 2017 11:26PM |
Supermec
I know of several people who have ordered 12V hot ends and received 24V versions instead (although marked as 12V). Firstly check that what you actually received is in fact a 12V hot end. Take a resistance across the heater wires, it should read around 3.6 ohms. If it reads over 10 ohms then it is a 24V version and it will only put out around 10W on 12V, which could be the reason that it is struggling to raise the temperature.
Check that the thermistor is fully in place in its hole in the heater block and secured. Also, check the thermistor resistance reading is correct for your machine. Most machines use ones that are 100 kohm at 25C (125 kohm at 20C).
Re: Prusa i3 - Hot End PID Autotune Fail - Timeout March 03, 2017 07:00PM |
Re: Prusa i3 - Hot End PID Autotune Fail - Timeout March 03, 2017 07:23PM |
Supermec
Vgala9
It would seem then that they have sent you a 24V version, they read around 14.4 ohms. I am absolutely certain that this is the cause of your problems. You could just get a replacement cartridge, but when you receive it check that one as well before going to the trouble of fitting it.
Best of luck.
