Thermal Runaway after Firmware Uldate March 18, 2017 12:59PM |
Re: Thermal Runaway after Firmware Uldate March 19, 2017 04:39AM |
Re: Thermal Runaway after Firmware Uldate March 20, 2017 11:31PM |
* If you get false positives for "Thermal Runaway" increase THERMAL_PROTECTION_HYSTERESIS and/or THERMAL_PROTECTION_PERIOD */ #if ENABLED(THERMAL_PROTECTION_HOTENDS) #define THERMAL_PROTECTION_PERIOD 60 // Seconds #define THERMAL_PROTECTION_HYSTERESIS 6 // Degrees Celsius
Re: Thermal Runaway after Firmware Uldate March 21, 2017 01:44PM |
Re: Thermal Runaway after Firmware Uldate March 21, 2017 05:01PM |
Supermec
I would put the period back to the original settings and increase the hysteresis to 8. However, before you increase the hysteresis, make absolutely sure that your part cooling fan is blowing below the tip of the nozzle, and not onto the nozzle or extruder heater block. If it blows onto the block it can affect the temperature and may cause similar problems. If you have an extruder cooling fan, then make sure that the heat-sink fins are horizontal and not vertical for the same reason.
Re: Thermal Runaway after Firmware Uldate March 21, 2017 06:37PM |
Re: Thermal Runaway after Firmware Uldate March 21, 2017 08:11PM |
Vgala9
I've now bumped it to 120 for the period and 10 for hysteresis. Your suggested mods found failure at identical location as previous.
Re: Thermal Runaway after Firmware Uldate March 22, 2017 05:03AM |
Re: Thermal Runaway after Firmware Uldate March 22, 2017 08:52AM |
Supermec
What filament were you printing, ABS or PLA, and what were the target temperatures for bed and extruder? I assume with the bed showing an actual tempeature of 86C that it was ABS. Some hot bed / PSU combinations are under powered and struggle to get the bed above around 86C unless in an enclosure. If your target bed temperature was above 86 this could be what has triggered the failure.
Re: Thermal Runaway after Firmware Uldate March 23, 2017 04:25PM |
Re: Thermal Runaway after Firmware Uldate May 04, 2017 07:56PM |
