setup problem tronxy p802m prusa i3 with cura
Posted by rainito
March 22, 2017 08:45AM
Hello to all guys, I'm here because I need help with cura software 2.4
The printer I have is a tronxy Prusa i3 p802m I've always used with repetier host and I never had any problems.
Lately I downloaded cura because I was reading that is higher and easier to use.
Start by saying that I had to force the update of the printer software for it to be recognized by cura and so I modified the 0.92 version I found on another site.
I set the printer profile as explained in the various guides by setting the size of the bed and of the extruder. In the section of gcode I left reprap (marlin) etc. Everything ok except when I go to start printing where I immediately noticed that the extruder makes a move without sense and sometimes print, then go over and back again to print etc etc. I think it is a problem of gcode but i tried all settings (reprap, repetier, makerbot etc.) but nothing change. Maybe someone can help me?
Re: setup problem tronxy p802m prusa i3 with cura
May 10, 2017 11:20PM
Try checking the start Gcode that Cura automatically adds
go to preferences, printers, machine settings,
Here is a sample of my start gcode
;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
;Print time: {print_time}
;Filament used: {filament_amount}m {filament_weight}g
;Filament cost: {filament_cost}
;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
;M109 S{print_temperature} ;Uncomment to add your own temperature line
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G92 E0 ;zero the extruded length
G1 F{travel_speed}
;Put printing message on LCD screen
M117 Printing...
What does yours look like?
