Maker Select v2 fan issue
Posted by stormhagen
April 03, 2017 06:35PM
Hi everyone,
Had my maker select for about a month now. Noticed that the print cooling fan run constantly despite having it off on control panel. Ran at very low rate with the original fan, wasn't a super big deal.
However, now I have installed the Ciii cooler and new radial fan. It still runs at low speed even when set to off (will change in speed according to % set but just never turns completely off) but it is a bigger problem now since the output is so much greater with the new fan and shroud. Have just been unplugging fan during initial layers for better adhesion and then plugging back in later on but would like to automate this process.
Extruder fan runs constantly so I know cables aren't swapped.
Thanks in advance for any help!
