Marlin/Arduino
Posted by Bee69
Marlin/Arduino
May 24, 2017 06:38AM
Hi guys mi trying to upload new firmware ( Marlin / Arduino ) using a new laptop and its giving this error.
Arduino: 1.5.8 (Windows 8), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=158 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\gisal\AppData\Local\Temp\build5554648623669385129.tmp\temperature.cpp -o C:\Users\gisal\AppData\Local\Temp\build5554648623669385129.tmp\temperature.cpp.o
C:\Users\gisal\AppData\Local\Temp\build5554648623669385129.tmp\temperature.cpp: In function 'void manage_heater()':
C:\Users\gisal\AppData\Local\Temp\build5554648623669385129.tmp\temperature.cpp:665:1: error: unable to find a register to spill in class 'POINTER_REGS'
C:\Users\gisal\AppData\Local\Temp\build5554648623669385129.tmp\temperature.cpp:665:1: error: this is the insn:
(insn 98 97 100 4 (set (reg/vconfused smileyF 103 [ pid_input ])
(memconfused smileyF (post_inc:HI (reg:HI 146 [ ivtmp.209 ])) [4 MEM[base: _110, offset: 0B]+0 S4 A8])) C:\Users\gisal\AppData\Local\Temp\build5554648623669385129.tmp\temperature.cpp:449 99 {*movsf}
(expr_list:REG_INC (reg:HI 146 [ ivtmp.209 ])
(nil)))
C:\Users\gisal\AppData\Local\Temp\build5554648623669385129.tmp\temperature.cpp:665: confused by earlier errors, bailing out
Error compiling.
Re: Marlin/Arduino
May 24, 2017 06:55AM
1.5.8 was a beta release of arduino, please don’t use that
grab 1.6.13 from [www.arduino.cc]
Re: Marlin/Arduino
May 24, 2017 07:00AM
Thanks
Re: Marlin/Arduino
May 27, 2017 08:57AM
Hi guys I get this when I try to upload firmware.
Arduino: 1.8.1 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
pData\Local\Temp\arduino_build_940310\sketch\Marlin_main.cpp.o"
In file included from C:\Users\gisal\AppData\Local\Temp\arduino_build_940310\sketch\SdFile.h:27:0,
from C:\Users\gisal\AppData\Local\Temp\arduino_build_940310\sketch\cardreader.h:8,
from C:\Users\gisal\AppData\Local\Temp\arduino_build_940310\sketch\Marlin_main.cpp:44:
SdBaseFile.h:38: error: using typedef-name 'fpos_t' after 'struct'
struct fpos_t {
In file included from C:\Users\gisal\AppData\Local\Temp\arduino_build_940310\sketch\Marlin.h:10:0,
from C:\Users\gisal\AppData\Local\Temp\arduino_build_940310\sketch\Marlin_main.cpp:30:
c:\users\gisal\downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr\avr\include\stdio.h:950:33: note: 'fpos_t' has a previous declaration here
__extension__ typedef long long fpos_t;
Using library LiquidCrystal at version 1.0.5 in folder: C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\libraries\LiquidCrystal
exit status 1
Invalid library found in C:\Users\gisal\Documents\Arduino\libraries\Marlin-PI3_Pro_C: C:\Users\gisal\Documents\Arduino\libraries\Marlin-PI3_Pro_C
Re: Marlin/Arduino
May 27, 2017 09:28AM
your using a firmware thats from the stone age...
a long time ago in a galaxy far away someone in their infinite wisdom decided that fpos_t would make a nice reserved keyword in the newer ardunio ide. Breaking all stone age reprap firmware.
If its still using the same file names you have to edit two files SdBaseFile.h and SdBaseFile.cpp
find all occurrences of fpos_t and change it to something else eg filepos_t
Do not miss any, or it will not work.
Edited 1 time(s). Last edit at 05/27/2017 09:34AM by Dust.
Re: Marlin/Arduino
May 27, 2017 01:01PM
Thanks for that. I'll try and get a newer firmware.
Re: Marlin/Arduino
May 28, 2017 01:14AM
Dust
Open the Arduino IDE, Open the Marlin Folder, and open the Marlin arduino file. The two files mentioned above will be tabs at the top of the page.
Dust
Ctrl+F will help you locate the offending text.
It works, it does. [forums.reprap.org] And it's a good excuse to play around in the firmware coding. Just make a copy, and name the copy 'somethingsomethingBackup'. That way if you have to start fresh, you don't have to go far.
FWIW; You could create more headache for yourself going to a newer version of Marlin than 'modding' the firmware you have that is working. i.e. "Now I have it compiled, but my stepper motors aren't running the right direction".
Edited 2 time(s). Last edit at 05/28/2017 01:21AM by VonRansak.
Re: Marlin/Arduino
May 28, 2017 08:03AM
Thanks for the info I think I'll get a newer version of Marlin.
Re: Marlin/Arduino
May 29, 2017 06:37AM
Hi guys
I've found a newer version of Marlin but it will not upload.
What am I doing wrong. I've included the first and last bits of code and the error's
C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\arduino-builder -dump-prefs -logger=machine -hardware C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware -tools C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\tools-builder -tools C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr -built-in-libraries C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\libraries -libraries C:\Users\gisal\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -ide-version=10801 -build-path C:\Users\gisal\AppData\Local\Temp\arduino_build_303281 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr -verbose C:\Users\gisal\Downloads\3D Printer\Software\Marlin-1.1.x\Marlin\Marlin.ino
C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\arduino-builder -compile -logger=machine -hardware C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware -tools C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\tools-builder -tools C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr -built-in-libraries C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\libraries -libraries C:\Users\gisal\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -ide-version=10801 -build-path C:\Users\gisal\AppData\Local\Temp\arduino_build_303281 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr -verbose C:\Users\gisal\Downloads\3D Printer\Software\Marlin-1.1.x\Marlin\Marlin.ino
Using board 'mega' from platform in folder: C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware\arduino\avr
Detecting libraries used...
"C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections,--relax -mmcu=atmega2560 -o "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281/Marlin.ino.elf" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\G26_Mesh_Validation_Tool.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\M100_Free_Mem_Chk.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\Marlin.ino.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\MarlinSerial.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\Marlin_main.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\Sd2Card.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\SdBaseFile.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\SdFatUtil.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\SdFile.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\SdVolume.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\blinkm.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\cardreader.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\configuration_store.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\dac_mcp4728.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\digipot_mcp4018.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\digipot_mcp4451.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\endstops.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\hex_print_routines.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\least_squares_fit.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\mesh_bed_leveling.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\nozzle.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\planner.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\planner_bezier.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\printcounter.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\qr_solve.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\serial.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\servo.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\stepper.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\stepper_dac.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\stepper_indirection.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\stopwatch.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\temperature.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\twibus.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\ubl.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\ubl_G29.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\ubl_motion.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\ultralcd.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\utility.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\vector_3.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281\sketch\watchdog.cpp.o" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281/core\core.a" "-LC:\Users\gisal\AppData\Local\Temp\arduino_build_303281" -lm
"C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281/Marlin.ino.elf" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281/Marlin.ino.eep"
"C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281/Marlin.ino.elf" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303281/Marlin.ino.hex"
Sketch uses 51744 bytes (20%) of program storage space. Maximum is 253952 bytes.
Global variables use 2734 bytes (33%) of dynamic memory, leaving 5458 bytes for local variables. Maximum is 8192 bytes.
C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr/bin/avrdude -CC:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr/etc/avrdude.conf -v -patmega2560 -cwiring -PCOM3 -b57600 -D -Uflash:w:C:\Users\gisal\AppData\Local\Temp\arduino_build_303281/Marlin.ino.hex:i
avrdude: Version 6.3, compiled on Dec 16 2016 at 13:33:19
Copyright (c) 2000-2005 Brian Dean, [www.bdmicro.com]
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : wiring
Overriding Baud Rate : 57600
avrdude: ser_open(): can't set com-state for "\\.\COM3"
avrdude: ser_drain(): read error: The handle is invalid.
avrdude: ser_send(): write error: sorry no info avail
avrdude: stk500_send(): failed to send command to serial port
avrdude: ser_recv(): read error: The parameter is incorrect.
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500_send(): failed to send the selected serial port avrdude: stk500_send(): failed to send does not exist or your board is not connected
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude done. Thank you.
Re: Marlin/Arduino
May 29, 2017 07:59AM
com3 is open by some other program, or windows is being windows and the machine needs a reboot.
or device has moved to a different com port, or you just havent plugged the board in.
You can only have one program talking to a com part at any one time. So you cant run arduino and say pronterface at the same time.
Best to reboot and make sure nothing else is using the com port
Edited 1 time(s). Last edit at 05/29/2017 08:00AM by Dust.
Re: Marlin/Arduino
May 29, 2017 01:08PM
Ok i've been messing about with things but Marlin still will not upload.
C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\arduino-builder -dump-prefs -logger=machine -hardware C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware -tools C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\tools-builder -tools C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr -built-in-libraries C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\libraries -libraries C:\Users\gisal\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -ide-version=10801 -build-path C:\Users\gisal\AppData\Local\Temp\arduino_build_303749 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr -verbose C:\Users\gisal\Downloads\3D Printer\Software\Marlin-1.1.x\Marlin\Marlin.ino
C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\arduino-builder -compile -logger=machine -hardware C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware -tools C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\tools-builder -tools C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr -built-in-libraries C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\libraries -libraries C:\Users\gisal\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -ide-version=10801 -build-path C:\Users\gisal\AppData\Local\Temp\arduino_build_303749 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr -verbose C:\Users\gisal\Downloads\3D Printer\Software\Marlin-1.1.x\Marlin\Marlin.ino
"C:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware\arduino\avr\cores\arduino" "-IC:\Users\gisal\Downloads\arduino-1.8.1-windows\arduino-1.8.1\hardware\arduino\avr\variants\mega" "C:\Users\gisal\AppData\Local\Temp\arduino_build_303749\sketch\Marlin.ino.cpp" -o "C:\Users\gisal\AppData\Local\Temp\arduino_build_303749\preproc\ctags_target_for_gcc_minus_e.cpp"
In file included from C:\Users\gisal\AppData\Local\Temp\arduino_build_303749\sketch\MarlinConfig.h:30:0,
from C:\Users\gisal\Downloads\3D Printer\Software\Marlin-1.1.x\Marlin\Marlin.ino:31:
Configuration.h:38: error: unterminated #ifndef
#ifndef CONFIGURATION_H
exit status 1
Re: Marlin/Arduino
May 29, 2017 05:36PM
now you have broken the configuration.h so its not compiling...
If your lucky you have just lost the last line
#endif // CONFIGURATION_H
if not then you need to get a new configuration.h and compare it with what you had and work out what you did.
Re: Marlin/Arduino
May 30, 2017 09:23AM
Thank you
Re: Marlin/Arduino
June 03, 2017 10:31PM
Been a while (6 months) since I used my Folgertech i3 Acrylic. Having to start anew as my old computer was stolen. I'm using Windows 7 and was wondering which is the best Arduino/Marlin/RepetierHost firmware combination. I have a 2004 LCD screen and would like to use it. Trying to remember which versions I was using before...not sure. Any help would be great. Thanks
Re: Marlin/Arduino
June 05, 2017 11:22PM
Flyer
No problem. Follow this link [forums.reprap.org] ... Then click on 'New Topic' winking smiley
