Problems with Prusa i3 Tronxy June 09, 2017 04:49PM |
Re: Problems with Prusa i3 Tronxy June 09, 2017 09:55PM |
dlw
First; the wiring system has been checked and checked and checked again with the wiring diagram. It is correct.
dlw
Also, what happens when pressing the reset button. What exactly does it reset?
Re: Problems with Prusa i3 Tronxy June 10, 2017 12:40AM |
Re: Problems with Prusa i3 Tronxy June 10, 2017 05:40AM |
Re: Problems with Prusa i3 Tronxy June 10, 2017 12:48PM |
Re: Problems with Prusa i3 Tronxy June 14, 2017 07:27AM |
Re: Problems with Prusa i3 Tronxy June 14, 2017 10:07AM |
MCcarman
5V !!!! End stops normally read 12V.
Are you getting 12v to the board?
No. 9.8V.
You say there is a problem with the comms so you are working with the display controls only but is that working with the PSU or only when connected to a computer.
If it only works when connected to a computer you may just be getting 5V via the USB and nothing from the PSU.
Can not get it recognized by my W7 laptop or Ubuntu PC. Do not think that is the printer's fault.
Its has been known for the supplied document to be wrong. And some times the instructions don't translate very well.
I can only suggest you check the wiring again.
