New P3Steel build June 22, 2017 08:20AM |
Re: New P3Steel build March 24, 2018 04:05AM |
Re: New P3Steel build April 08, 2018 06:34AM |
Photo | Description |
A little close up of the electronics with the power regulator and the ftdi communication chip. | |
A general view of the control board it's a MKS GEN v1.2 (very cheap, around 25 Euro) BELOW: there is the Sevenswitch MOSFET borad (the light brown one) and the 5v fly down regulator. |
A view of the electric connession block for ring or spade connectors. LEFT: the 5A automotive fuse that bring the 12V positive to the H0 HotEnd, This is done on pourpose, as not passing the 12V positive power to the board fuse, doing so if some went wrong the automotive fuse blow and you can replace it an see what element is the culprit. |
A view of the fuse holders for the fans, the automotive fuses are too big to protect the fans that absorb 0.1 - 0.2 A max each, i have used 300mA fuse, LEFT: Screw connectors for E0 E1 and X axis. RIGHT: "RRD fan extender" that drives the two extruder fans using "AUX 1" pins 57 and 58 BELOW: Red wire that exit from the screw teminal bring the 12V through an automotive fuse to the H0 HotEnd, that you see in the preceding image |
Re: New P3Steel build April 10, 2018 01:03PM |
The IP adress shown on the display | |
The Breadborad with the ESP-12E, a 5v to 3.3V converter and 4 10K resistors, two 220uF condenser, 1 1n4148 diode for the shift level conversion on RX pin of the ESP-12E, and a push button for the reset of the ESP-12E | |
The connession on AUX 1, blue wire on row 2is the TX pin, white wire on row 2 is the RX pin of the ESP-12E |
Re: New P3Steel build April 10, 2018 04:05PM |
Re: New P3Steel build April 25, 2018 10:03AM |
Re: New P3Steel build May 31, 2018 12:30PM |
New fuse holder. Stackable Automotive type, very cheap 0.50 Euro each. New printed fuse holder mount, with a p3steel look, this was the first ABS printing test, it was not too bad, but it is not perfect, maybe some tweking in the Slic3r setting are needed, but apart from the ahestethic is very strong (Spanish ABS-HI). |
Installed a capacitive probe for ABL 18mm one. Powered at 12V and with same diode hack used to achieve level conversion for the ESP12E. |
New placement of power wirings. | |
New extruder. It is a cheap chinese one modified replacing the gear with MK8 type, new plain bearing and a less stronger spring. |
Installed a retainer screw on the Z axis nylon nuts. Otherwise the nylon nut tends to slips off the hole. |
