Cura help
Posted by Bee69
Cura help
July 11, 2017 07:06AM
Hi Guys/Girls.
I'm trying to print a lid i knocked up in sketchup but when i try to print it prints it all messed up. I've included two pics one of the file in Cura and the others are what it's printnig
What am I doing wrong.
Thanks
Adrian
Edited 2 time(s). Last edit at 07/11/2017 07:08AM by Bee69.
open | download - Screenshot (2).png (237.2 KB)
open | download - WIN_20170711_11_48_01_Pro.jpg (35 KB)
open | download - WIN_20170711_11_48_55_Pro (2).jpg (37 KB)
open | download - WIN_20170711_11_48_55_Pro.jpg (36.3 KB)
Re: Cura help
July 11, 2017 06:10PM
The 0.06mm next to the high quality in the profile, is that referring to layer height? (Probably why its a 21h print, should only be 2 at max). If so that is way to high for a box lit with no detail in the z so those extra layers are wasted, go with something like 0.2mm or 0.25mm
The gaps between the hex holes already look close, i would get rid of the solid infill (maybe a 40%) and have perimeters set to 4 or 5.
You may need to slow down the print speed to get the detail in the hex holes, or you might be over extruding and losing the detail.
Re: Cura help
July 11, 2017 09:19PM
I Agree with scottybfg layer would be fine between 0.15 - 0.25 with a infill of 40%.
I would rotate the Pi Board Box Lid 180 leaving the Face level on the Bed and disable the support material.
It appears you may be too hot on the filament, what temperature are you using.
I have two Printers one prints well at 192C the other at 198C.
Edited 5 time(s). Last edit at 07/11/2017 09:30PM by Roberts_Clif.
Re: Cura help
July 11, 2017 10:59PM
Roberts_Clif
Good pick, to me it looked like it was one flat plate, but it it does have sides rotate, you will never get that top detail if it needs support / bridging.
Re: Cura help
July 12, 2017 04:13AM
Hay Guys thank you for the input. It's much appricated and I will make the adjustments you mention.
The lid is suposed to have holes through it but when I print it it solid. Any ideas as to why.
Thanks
Adrian
Re: Cura help
July 12, 2017 07:17AM
can you attach the stl file, and exported cura settings.
Re: Cura help
July 12, 2017 08:42AM
Hi guys I've tried the settings you mentioned and what a difference It's made.
The quality is a lot better and the time is one tenth of the old time.
It will not let me attach a file bigger than 614.4 KB and the STL is 10 meg
Thanks
Adrian
Edited 1 time(s). Last edit at 07/12/2017 11:42AM by Bee69.
Re: Cura help
July 12, 2017 03:24PM
Hi guys this is suposed to be a box. Why did it do this.
open | download - 20049575_10154798936006033_1108801792_o.jpg (164.6 KB)
open | download - 19911525_10154798935956033_770915562_o.jpg (277.8 KB)
Re: Cura help
July 12, 2017 05:39PM
I would guess 0 bottom layers selected in cura settings
Re: Cura help
July 13, 2017 02:45PM
Hay Guys thank you for the input. It's much appricated.
Thanks
Adrian
Re: Cura help
July 14, 2017 09:23AM
It appears you need to cool your print. Do you have A duct fan pointed at the print, If so you need to have at lease a fan speed of 50% to do the bridging.
What kind of 3D Printer are you using.
Re: Cura help
July 15, 2017 06:33AM
The print is cooled and its a ducted fan.The printer is a geeetech I3
