print problems
August 03, 2017 04:10AM
I have just recovered from a power surg, which played havoc with the electronics.
Now I have it back printing, but in the wrong place on the plate.
It is printing to one side and the back, how can I get it back to printing in the centre. Thanks.
Re: print problems
August 03, 2017 09:32AM
As you have not stated what firmware will assume Marlin.
If you have Marlin firmware this should work.
Do a 'lets say factory reset'
Cura "PronterFace"
In your printer software send a M502 ' This will send the command to read firmware defaults.
Then
In your printer software send a M500 ' This will send the command to Save settings to EEProm.
Edited 1 time(s). Last edit at 08/03/2017 09:32AM by Roberts_Clif.
Re: print problems
August 03, 2017 02:44PM
Then
Hi
How do you do that in Cura.
Thanks
Adrian
Re: print problems
August 03, 2017 10:13PM
Start Cura 15.04.6 ("any thing else may look different than this")
Plug USB cable into Computer and 3D Printer
Click on Machine "Select The Printer You Are Using Radio button"
Then Click on Machine Settings
A new Window will appear Select Serial Port "do not select auto"
Select Baudrate "Set your Baudrate"
Set up your print bed size if not already done.
Load a STL anything will do as we will not be printing it.
After it is loaded Click on "Print to USB"
as seen in image below
If you do not see this then you need to re-configure Cura.
Edited 8 time(s). Last edit at 08/03/2017 11:37PM by Roberts_Clif.
Re: print problems
August 04, 2017 02:41AM
Hi and thanks for that but my version of Cura is 2.5.0 and looks nothing like that.
Ive started fresh both Marlin and Arduino and I keep getting this sort of error do I just // them out or do I have to put something in.
Thanks for the help
MarlinSerial.cpp:141: error: 'rx_buffer' was not declared in this scope
const uint8_t h = rx_buffer.head,
MarlinSerial.cpp:148: error: 'i' was not declared in this scope
if (i != rx_buffer.tail) {
In file included from C:\Users\gisal\AppData\Local\Temp\arduino_build_134620\sketch\MarlinSerial.cpp:32:0:
C:\Users\gisal\AppData\Local\Temp\arduino_build_134620\sketch\MarlinSerial.cpp: In function 'void USART5_RX_vect()':
MarlinSerial.h:64: error: 'UDR5' was not declared in this scope
#define M_UDRx SERIAL_REGNAME(UDR,SERIAL_PORT,)
C:\Users\gisal\AppData\Local\Temp\arduino_build_134620\sketch\MarlinSerial.cpp:360:30: note: in expansion of macro 'M_UDREx'
while (!TEST(M_UCSRxA, M_UDREx))
C:\Users\gisal\AppData\Local\Temp\arduino_build_134620\sketch\MarlinSerial.h:52:63: note: in definition of macro 'SERIAL_REGNAME_INTERNAL'
#define SERIAL_REGNAME_INTERNAL(registerbase,number,suffix) registerbase##number##suffix
C:\Users\gisal\AppData\Local\Temp\arduino_build_134620\sketch\MarlinSerial.h:64:28: note: in expansion of macro 'SERIAL_REGNAME'
C:\Users\gisal\AppData\Local\Temp\arduino_build_134620\sketch\MarlinSerial.cpp:362:7: note: in expansion of macro 'M_UDRx'
M_UDRx = c;
exit status 1
Edited 2 time(s). Last edit at 08/05/2017 09:28AM by Bee69.
Re: print problems
August 04, 2017 04:54AM
Looks like you set the serial port in firmware to something bad... (just had another case of this recently)
it should be 0, its the serial port on the controller, not the serial port on the pc.
ie: in configuration.h
#define SERIAL_PORT 0
Edited 1 time(s). Last edit at 08/04/2017 05:04AM by Dust.
Re: print problems
August 04, 2017 08:55AM
OK I've uploaded the firmware but now the X axis stepper is ticking. and my LCD REPRAP DISCOUNT SMART CONTROLLER does not work.
I have noticed that the ribbon cable socket is the other way around on this new board. The old board is the top one.
Edited 3 time(s). Last edit at 08/04/2017 09:04AM by Bee69.
Re: print problems
August 04, 2017 05:36PM
Roberts_Clif
Cura "PronterFace"
Then
Thanks but it did not work it is still the same, printing at the back right corner, in fact it is trying to print slightly of board in both back and right edges.
Re: print problems
August 05, 2017 07:35AM
Are you printing from SD or a host,
If host, check the bed sizes are still set correctly.
