Adding an LCD to Ramps 1.4
Posted by vfwfw
August 26, 2017 09:31AM
I have recently built a Prusa i3 clone with the Ramps 1.4 board and I am trying to add an LCD...
[www.ebay.com.au]
I am using the Marlin firmware, and have added the u8glib library to the arduino.cc software. I have uncommented the following line in Configuration.h
#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
however when I try to complie, I get an erro that says - 'min_software_endstops' was not declared in this scope
what does this mean and how do i fix it?
Re: Adding an LCD to Ramps 1.4
August 27, 2017 06:26AM
check these lines in config.h
// If enabled, axes won't move below MIN_POS in response to movement commands.
#define MIN_SOFTWARE_ENDSTOPS
// If enabled, axes won't move above MAX_POS in response to movement commands.
#define MAX_SOFTWARE_ENDSTOPS
Edited 1 time(s). Last edit at 08/27/2017 06:26AM by obewan.
