Re: Leadscrew August 29, 2017 12:23PM |
Re: Leadscrew August 30, 2017 01:28AM |
FA-MAS
You can use the calculator for the math. http://www.prusaprinters.org/calculator/
It seems you know the distance between the threads. But that may not be what you need to put in the calculator, depending on how many starts it has. Look at the end of the screw and you'll see it will look like there is either 1, 2, 4 or more parts where thread starts. If it's more than 1, then you'll use 2mm as the pitch in the calculator. If it's more than 1, multiply 2mm by however many starts and use that as the pitch in the calculator.
Re: Leadscrew August 30, 2017 12:28PM |
Re: Leadscrew August 30, 2017 12:56PM |
Re: Leadscrew August 30, 2017 01:49PM |
Re: Leadscrew August 30, 2017 03:30PM |
Re: Leadscrew August 30, 2017 05:15PM |
Re: Leadscrew August 30, 2017 07:33PM |
Re: Leadscrew August 31, 2017 05:37AM |
Re: Leadscrew August 31, 2017 12:26PM |
Re: Leadscrew August 31, 2017 12:36PM |
Bee69
Thank you Clif
When I tried to use the calculator I could not do the 2mm pitch presets for the LeadScrew.
Re: Leadscrew September 02, 2017 09:43PM |
Re: Leadscrew September 03, 2017 01:41AM |
erniehatt
Hi Guys, sorry for jumping in on another's thread, but it is appropriate for my problem.
I have just changed over my Y axis from belt drive to lead thread, and am having problems.
I entered the 400 as did Bee69, but I am getting no movement, I can hear the motor trying to turn but no movement,
I also changed the motor from nema17 to 14, maybe this is the problem, I don't know.
I checked all voltages on the drivers, and they are all 0.47 volts.
I hope someone will be able to help me here. Thanks.
Re: Leadscrew September 03, 2017 05:11AM |
Re: Leadscrew September 03, 2017 10:56AM |
erniehatt
Ok found part of the problem, the motor must be stuffed, changed it over and I have now got movement.
But it is not moving far enough, I jog it by 10 mm and it only reaches half way and it tells me it has gone the 200, I am assuming this is the Esteps I have 400 in there at the moment, any ideas.
Press home and it will do that
Re: Leadscrew September 03, 2017 01:48PM |
obewan
Sounds like you motor is struggling with the extra speed.
So, basically you have gone from ~82 steps/mm up to now 400 steps/mm , you will have to also lower the max speed so you are not trying to drive the motor too fast (ie the buzzing noise you here)
X Y Z E
#define DEFAULT_MAX_FEEDRATE { 300, 300, 5, 25 }
try changing the Y 300 to about 75.
you may also need to reduce the Y acceleration setting
Re: Leadscrew September 03, 2017 10:56PM |
Re: Leadscrew September 03, 2017 11:26PM |
Re: Leadscrew September 03, 2017 11:48PM |
Re: Leadscrew September 03, 2017 11:53PM |
erniehatt
Yes using the same lead screw..
I have just got it printing ok so far, No jumping as yet.
The original acceleration was 250, that seemed to make it jump 16mm, changed as suggested it jumped almost 50mm, so I increased it to 300 now it works.
I think I will leave it at that for the time being, its a bit squeaky while laying the out lines, I can live with that.
Thanks for the help.
Re: Leadscrew September 04, 2017 04:13AM |
Re: Leadscrew September 04, 2017 04:18AM |
Re: Leadscrew September 04, 2017 04:42AM |
erniehatt
looks like I spoke to soon, it was printing great got about 2/3 of the way through on a fairly large print, then shifted towards the front about 5 mm.
Got me beat, I wonder if there could be a cliche in the motor,or even the ramps I wouldn't have thought so, but who knows.
Carries on like this for much longer I will have to go back to belt drive, shame as quality is good.
Re: Leadscrew September 04, 2017 08:55AM |
Re: Leadscrew September 04, 2017 07:00PM |
Re: Leadscrew September 04, 2017 07:27PM |
Re: Leadscrew September 05, 2017 02:08AM |
Re: Leadscrew September 05, 2017 05:55PM |
Re: Leadscrew September 05, 2017 06:53PM |
