Re: Leadscrew September 05, 2017 10:28PM |
Re: Leadscrew September 06, 2017 06:06PM |
Re: Leadscrew September 07, 2017 07:11PM |
Re: Leadscrew September 08, 2017 01:07AM |
#define DEFAULT_AXIS_STEPS_PER_UNIT {80, 410.6, 410.6, 837.00} // default steps per unit for ***** MakiBox A6 ***** #define DEFAULT_MAX_FEEDRATE {60, 40, 20, 45} // (mm/sec) #define DEFAULT_MAX_ACCELERATION {2000,75,30,10000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinforge 40+, for older versions raise them a lot. #define DEFAULT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 3000.
Re: Leadscrew September 08, 2017 02:59AM |
scottybfg
Im guessing the above is how your settings look now. If you are seeing an issue with the x that was not there before then I think you may have changed the default_acceleration, this would affect all the axis
Re: Leadscrew September 09, 2017 02:41AM |
Re: Leadscrew September 09, 2017 04:14AM |
Re: Leadscrew September 09, 2017 08:02AM |
Re: Leadscrew September 11, 2017 03:46AM |
Re: Leadscrew June 05, 2021 02:36PM |
