My first 3D Printer build - RepRap Prusa i3 Rework
Posted by MvdO79
August 30, 2017 06:48PM
Hi, so I am building my first 3D printer and come a long way (RepRap Prusa i3 Rework).
I want to share an image of an print so hopefully you guys know what's wrong.
Any directions would be awesome.
To me it looks like somewhere at 2 o clock in the circle there is a line that goes a bit to the inner center of the circle, every time the nozzle bumps a bit over it, finally creating a mess.
Mechanically I can't think of anything anymore to tweak or change, using Pronterface as software, and me not being familiar with it, could be possible the reason why it's not printing perfect.
So any directions would be welcome!
Thanks, Marco.
Edited 2 time(s). Last edit at 08/30/2017 06:49PM by MvdO79.
open | download - IMG_20170831_003607.jpg (527.4 KB)
open | download - IMG_20170831_003643.jpg (475.8 KB)
Re: My first 3D Printer build - RepRap Prusa i3 Rework
September 03, 2017 07:00PM
Check the belt tightness.
September 03, 2017 07:23PM
number40fan
Thanks, checked that already.
Started with Cura now, way simpler.
What I do notice is a sort of bump every time a certain position is reached, that's no good...
September 04, 2017 02:12AM
Is the bump there when the bed is moving or the carriage? Can you disable the motors and move either one of them and feel the bump?
September 04, 2017 02:16AM
Are you talking about these bumps?
September 04, 2017 09:45AM
number40fan
When I disable the motors I can't really find out or feel that bump, that's so frustrating.
When I look at the printer while printing I don't see a bump happening looking to the carriage, but the bed does bump a little bit, so it must be the bed.
When I was tightening the belt I tried to move the bed backwards and forwards without a belt, that felt smooth.
I'll have a go and test print without filament to check where this is coming from.
September 04, 2017 09:52AM
number40fan
Indeed there you can see something is not going right, after I saw that I checked the printer and saw that bump happening on the machine which causes this bump in the print.
September 04, 2017 10:01AM
Also, right now I am calibrating the space between the nozzle and bed with a piece of a4 paper, is it better to use shims then that?
September 04, 2017 04:08PM
Paper is what I use. You just have to get the feel for it.
What I circled in the pictures is where the start and stop of the lines being laid down are. Have you calibrated the extruder?
Edited 1 time(s). Last edit at 09/04/2017 04:11PM by number40fan.
September 04, 2017 05:00PM
number40fan
I'll go and focus on calibrating the extruder, thanks.
