nozzle don't near touch when i used auto bed level October 11, 2017 04:06PM |
/** * Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN * * Enable this option for a probe connected to the Z Min endstop pin. */ #define Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN /** * Z Servo Probe, such as an endstop switch on a rotating arm. */ #define Z_ENDSTOP_SERVO_NR 0 // Defaults to SERVO 0 connector. #define Z_SERVO_ANGLES {132,35} // Z Servo Deploy and Stow angles #define X_PROBE_OFFSET_FROM_EXTRUDER 30 // X offset: -left +right [of the nozzle] #define Y_PROBE_OFFSET_FROM_EXTRUDER -12 // Y offset: -front +behind [the nozzle] #define Z_PROBE_OFFSET_FROM_EXTRUDER 6.79 // Z offset: -below +above [the nozzle] // Number of servos // // If you select a configuration below, this will receive a default value and does not need to be set manually // set it manually if you have more servos than extruders and wish to manually control some // leaving it undefined or defining as 0 will disable the servo subsystem // If unsure, leave commented / disabled // #define NUM_SERVOS 1 // Servo index starts with 0 for M280 command // Delay (in milliseconds) before the next move will start, to give the servo time to reach its target angle. // 300ms is a good value but you can try less delay. // If the servo can't reach the requested position, increase it. #define SERVO_DELAY { 300 }
Re: nozzle don't near touch when i used auto bed level October 11, 2017 04:13PM |
Re: nozzle don't near touch when i used auto bed level October 11, 2017 06:00PM |
Admin Registered: 14 years ago Posts: 7,221 |
Re: nozzle don't near touch when i used auto bed level October 11, 2017 11:32PM |
Re: nozzle don't near touch when i used auto bed level October 11, 2017 11:40PM |
