Tronxy Z Axis wont move (Melzi V2) December 04, 2017 12:38AM |
Re: Tronxy Z Axis wont move (Melzi V2) December 04, 2017 06:25AM |
Re: Tronxy Z Axis wont move (Melzi V2) December 04, 2017 01:06PM |
obewan
This sounds like the usual max z feedrate being set too high in the configuration.h in marlin default firmware
ie
#define DEFAULT_MAX_FEEDRATE { 300, 300, 5, 25 }
try reduceing the 5 to a 2 and recompiling firmware
Re: Tronxy Z Axis wont move (Melzi V2) August 03, 2018 06:55PM |
obewan
ie
Re: Tronxy Z Axis wont move (Melzi V2) August 07, 2018 07:40AM |
Re: Tronxy Z Axis wont move (Melzi V2) August 07, 2018 08:57AM |
Admin Registered: 13 years ago Posts: 7,001 |
M203 Z2 M500
Re: Tronxy Z Axis wont move (Melzi V2) August 07, 2018 04:24PM |
Dust
Melzi's are a PITA
You have to add the sanguino. support to the arduino IDE, as it doesn't come with it...
But before you go that that extreme Just adjust the max fead rate of Z in eeprom
ie send this to the printer
M203 Z2 M500
The first line sets the Z max feed rate to 2
the second saves this to eeprom. (as long as it replied ok)
If you still want to compile the firmware see this [dustsreprap.blogspot.com]
Its still the same for all newer arduino IDE's
as for what cpu is either a 644p or a 1284p
Look at the number of the large black chip
if its a 644p it crap, not enough flash memory to run current marlin,
even the 1284p is getting tight (can't enable all features)
