Noise on x axis with new LM8UU 24mm bearings January 09, 2018 08:16AM |
Re: Noise on x axis with new LM8UU 24mm bearings January 10, 2018 03:27AM |
Re: Noise on x axis with new LM8UU 24mm bearings January 10, 2018 04:03AM |
o_lampe
Almost sounds like the belt is scratching along somehwere. Or the printed bearings are too loose a fit and start rattling.
Re: Noise on x axis with new LM8UU 24mm bearings January 10, 2018 10:26AM |
Re: Noise on x axis with new LM8UU 24mm bearings January 10, 2018 12:39PM |
MKSA
PLA is not suitable to make good bearings and furthermore to get good bearings (made from Igus filament for ex.) they must be adjusted for minimal play (reamer or heat gun).
Minimal play means that everything must be properly constrained, well aligned. If not, polymer bearings will be hard to move, may seize. Too much play, they may rattle. Lubricant will help hiding these.
To get a smooth movement with no play, no lube is in fact much more difficult than with linear ball bearings.
LM and similar bearings because of the steel balls, will force but still move while wearing out quickly, themselves or the smooth rod if made of SS.
It is why all these crappy machines use them, mounting them via flexible means (non press fit, tie wrap, flexible frame ....) hoping they will last for some time.
Often the nerve wrecking noise leads to the user being worn out before.
Sintered bronze bushings are also an alternative.
Re: Noise on x axis with new LM8UU 24mm bearings January 11, 2018 02:28AM |
Re: Noise on x axis with new LM8UU 24mm bearings January 11, 2018 02:37AM |
Re: Noise on x axis with new LM8UU 24mm bearings January 21, 2018 01:56PM |
Re: Noise on x axis with new LM8UU 24mm bearings February 28, 2018 07:06AM |
Re: Noise on x axis with new LM8UU 24mm bearings February 28, 2018 12:13PM |
Re: Noise on x axis with new LM8UU 24mm bearings February 28, 2018 12:46PM |
MKSA
Reread what I wrote.
Re: Noise on x axis with new LM8UU 24mm bearings February 28, 2018 03:41PM |
Re: Noise on x axis with new LM8UU 24mm bearings February 28, 2018 03:49PM |
