Can't figure out why I'm printing like this... January 18, 2018 08:51AM |
Re: Can't figure out why I'm printing like this... January 18, 2018 10:44AM |
Re: Can't figure out why I'm printing like this... January 18, 2018 03:44PM |
Admin Registered: 13 years ago Posts: 7,000 |
Re: Can't figure out why I'm printing like this... January 18, 2018 04:23PM |
MKSA
Just that the dial holder you use is bad.
Unless you are lucky, there is no way the holes in it match exactly the rod diam and rod center to center distance. Therefore they will bend when you place the dial and the distance you measure will not be correct.
The ABL should correct it and may be it doesn't work too ?
You may also have excessive play somewhere (The "grinding" bearings may have ground the rods badly if they are not the correct steel as often.
Ensure everything is tight and try the simple method, a sheet of paper to make sure all is flat. Recheck to make sure your adjustment really work. A plane is 3 points and here you adjust with 4 screws.
If //, squareness ... it is pretty bad, you may simply not be able to adjust.
Re: Can't figure out why I'm printing like this... January 18, 2018 04:27PM |
Dust
which ABL method did you try there are several...
One common ABL only compensates for bed tilt not irregular surface Like lit looks like you have there
Re: Can't figure out why I'm printing like this... January 19, 2018 07:14AM |
MKSA
Dust
Dust
Re: Can't figure out why I'm printing like this... January 19, 2018 06:32PM |
Re: Can't figure out why I'm printing like this... January 21, 2018 02:44AM |
Re: Can't figure out why I'm printing like this... January 21, 2018 03:20AM |
Re: Can't figure out why I'm printing like this... January 21, 2018 08:46AM |
auggie246
Before I used Unified Bed Leveling (UBL), I was using bilinear leveling with BLTouch. everything was fine and calibrated. a 20mm calibration cube would come out ~20mm.
Re: Can't figure out why I'm printing like this... January 22, 2018 08:12AM |
