Tevo Tarantula firmware update
Posted by mjo3
February 14, 2018 03:57AM
I’m trying to update my Tevo Tarantula firmware to Marlin..and suddenly my lcd is showing 2 rows of white squares,instead of normal display..i'm using arduino 1.6.8 right now. what is the cause of this problem?is there any way i can reset back to factory firmware?
thanks
open | download - 1.jpg (47.2 KB)
Re: Tevo Tarantula firmware update
February 14, 2018 08:19AM
What display did you select for your controller in configuration.h
February 14, 2018 07:42PM
my problem is solved..i'm using arduino 1.6.8 before this,but yesterday i'm trying to flash it again with the current arduino and it works..
thanks
February 14, 2018 11:16PM
Always someone here to try and help, It is always better if you can find your own solutions. So am thankful you learned the solution for yourself.
