REPRAPGURU - Prusa i3 Kit - Heated Bed fatal error when running Fan > 50%
Posted by tomoneill1991
February 26, 2018 02:32PM
Hello everyone!!!
I've narrowed down the issue to this:
When the Extruder fan is running above 50% the hotbed begins to lose temperature. My bed is set to 70C. If the fan is moving at 75%-100% then the hotbed will begin to lose temperature quickly. Once that occurs I'll receive one of two Fatal Errors:
13:54:11.269 : Error:Heating failed, system stopped! Heater_ID: bed
13:54:11.271 : Error: Printer halted. kill() called!
and/or
17:16:53.312 : Error:Thermal Runaway, system stopped! Heater_ID: bed
17:16:53.312 : Error: Printer halted. kill() called!
[i.imgur.com]
This looks to be a result of a fail-safe to prevent the printer from burning up in case the extruder or hotbed's heating elements came loose.
I've confirmed both the Fan and Hotbed can work independently.
Any thoughts? The instructions said I should have the fan on at 100% while printing to prevent clogs and improve print quality.
Edited 4 time(s). Last edit at 02/26/2018 08:54PM by tomoneill1991.
Re: REPRAPGURU - Prusa i3 Kit - Heated Bed fatal error @ 60C
February 26, 2018 05:45PM
It look like you are running the fan at full speed, Myself I only run the fan between 46-70%, try and see if it helps.
February 26, 2018 06:24PM
Thanks for the advice.
Unfortunately, I got the same error message:
18:17:15.584 : T:22.05 /0.00 B:48.69 /70.00 @:0 B@:127
18:17:16.582 : T:22.09 /0.00 B:48.75 /70.00 @:0 B@:127
18:17:17.583 : T:22.16 /0.00 B:48.77 /70.00 @:0 B@:127
18:17:18.577 : T:22.16 /0.00 B:48.77 /70.00 @:0 B@:127
18:17:19.580 : T:22.21 /0.00 B:48.82 /70.00 @:0 B@:127
18:17:20.576 : T:22.28 /0.00 B:48.85 /70.00 @:0 B@:127
18:17:21.576 : T:22.26 /0.00 B:48.85 /70.00 @:0 B@:127
18:17:22.575 : T:22.35 /0.00 B:48.85 /70.00 @:0 B@:127
18:17:23.575 : T:22.37 /0.00 B:48.92 /70.00 @:0 B@:127
18:17:24.574 : T:22.35 /0.00 B:48.92 /70.00 @:0 B@:127
18:17:25.574 : T:22.37 /0.00 B:48.92 /70.00 @:0 B@:127
18:17:26.573 : T:22.37 /0.00 B:48.99 /70.00 @:0 B@:127
18:17:27.572 : T:22.37 /0.00 B:49.00 /70.00 @:0 B@:127
18:17:28.572 : T:22.37 /0.00 B:49.00 /70.00 @:0 B@:127
18:17:29.573 : T:22.37 /0.00 B:49.05 /70.00 @:0 B@:127
18:17:30.571 : T:22.37 /0.00 B:49.08 /70.00 @:0 B@:127
18:17:31.570 : T:22.37 /0.00 B:49.08 /70.00 @:0 B@:127
18:17:32.569 : T:22.37 /0.00 B:49.08 /70.00 @:0 B@:127
18:17:33.570 : T:22.37 /0.00 B:49.15 /70.00 @:0 B@:127
18:17:34.568 : T:22.37 /0.00 B:49.15 /70.00 @:0 B@:127
18:17:35.567 : T:22.37 /0.00 B:49.15 /70.00 @:0 B@:127
18:17:36.567 : T:22.37 /0.00 B:49.23 /70.00 @:0 B@:127
18:17:37.566 : T:22.37 /0.00 B:49.23 /70.00 @:0 B@:127
18:17:38.566 : T:22.37 /0.00 B:49.23 /70.00 @:0 B@:127
18:17:39.562 : T:22.37 /0.00 B:49.31 /70.00 @:0 B@:127
18:17:40.565 : T:22.37 /0.00 B:49.31 /70.00 @:0 B@:127
18:17:41.560 : T:22.40 /0.00 B:49.31 /70.00 @:0 B@:127
18:17:42.561 : T:22.40 /0.00 B:49.38 /70.00 @:0 B@:127
18:17:43.559 : T:22.40 /0.00 B:49.38 /70.00 @:0 B@:127
18:17:44.559 : T:22.42 /0.00 B:49.38 /70.00 @:0 B@:127
18:17:45.558 : T:22.40 /0.00 B:49.43 /70.00 @:0 B@:127
18:17:46.559 : T:22.49 /0.00 B:49.46 /70.00 @:0 B@:127
18:17:47.558 : T:22.66 /0.00 B:49.46 /70.00 @:0 B@:127
18:17:48.557 : T:22.66 /0.00 B:49.48 /70.00 @:0 B@:127
18:17:49.556 : T:22.61 /0.00 B:49.54 /70.00 @:0 B@:127
18:17:50.556 : T:22.73 /0.00 B:49.54 /70.00 @:0 B@:127
18:17:51.557 : T:22.66 /0.00 B:49.54 /70.00 @:0 B@:127
18:17:52.555 : T:22.73 /0.00 B:49.61 /70.00 @:0 B@:127
18:17:53.554 : T:22.70 /0.00 B:49.62 /70.00 @:0 B@:127
18:17:54.553 : T:22.70 /0.00 B:49.62 /70.00 @:0 B@:127
18:17:55.554 : T:22.68 /0.00 B:49.65 /70.00 @:0 B@:127
18:17:56.552 : T:22.66 /0.00 B:49.69 /70.00 @:0 B@:127
18:17:57.552 : T:22.75 /0.00 B:49.69 /70.00 @:0 B@:127
18:17:58.551 : T:22.75 /0.00 B:49.71 /70.00 @:0 B@:127
18:17:59.341 : Error:Heating failed, system stopped! Heater_ID: bed
18:17:59.341 : Error Printer halted. kill() called!
Edited 1 time(s). Last edit at 02/26/2018 06:24PM by tomoneill1991.
