Upgrade to Marlin 1.1 Auto Home Issues February 28, 2018 07:19AM |
#define X_MIN_ENDSTOP_INVERTING false // (+10v Switch Open, 0v When Switch Closed)
Re: Upgrade to Marlin 1.1 Auto Home Issues March 01, 2018 02:12AM |
Re: Upgrade to Marlin 1.1 Auto Home Issues March 01, 2018 04:15AM |
X endstop on the left
all are MN end stops and should be wired to the MIN pins on the RAMPs
From your configuration file your switches are configured to be normally closed
With the axis off the end stops what does a M119 command from Repetier give you? When you manually press an endstop switch what does a M119 give you?
10:08:21.052 : echoD card ok This as far as I can tell is the final output of the printer, after that it normally sends temperature data. 10:08:52.748 : Communication timeout - reset send buffer block 10:08:52.758 : Error:Line Number is not Last Line Number+1, Last Line: 0 10:08:52.758 : Resend: 1
Re: Upgrade to Marlin 1.1 Auto Home Issues March 03, 2018 06:55PM |
