In case anyone is interested, after some time, thinking about it and figuring how I might go about it, I finally upgraded the way the Y-Axis on my i3 Clone rode. I got a few more pieces of 2020 Extrusion, two ling pieces of 500mm long 8mm linear rod, four linear bearing mounted in aluminum blocks, and a Gulf Coast Robotics V2 Aluminum Y Carriage plate. I also HIGHLY recommend
this style of T-Nut over the cheap ones that came with my printer that you have to twist to get to grab. They were a huge pain and sucked.
In putting it all together, I discovered that the base was not square as originally assembled. Probably didn't make a huge difference, but who knows. I essentially took it all apart and put it back together from the base up, so everything is as perfectly square as it can be no, I think. With the new T-Nuts, everything is held together much better. The build plate is insanely more solid now, and to say it rides smooth on the linear rods and bearings compared to the wheels on the 2040 extrusion doesn't do it justice. The 'waves' that used to be in my prints are now gone. While the build plate does not seem to be truly perfectly flat, it's MUCH better now than it was riding on the 2020 rail and wheels. MUCH less variation. Even got some PETG prints to work nice now. Had lots of problems with the first layer, quite possibly due to the build plates height variation before. I lost about 1/2" in build height, but I've never printed anything that tall anyway.
Here you can see in the print on the left, the 'waves' introduced into the print by the rollers with the original setup, gone on the right print on the new setup
The only thing that I saw now that I haven't had before is these 'flyaways' not sure if or how they could be related to the change in how the build plate rides, but I've printed several of these before and never had them before. The small PETG prints were near perfect, except for some PETG related stringiness and blob issues (The pieces sitting on the build plate are PETG prints after the upgrade). Right now, I don't think I want to try a long PETG print with now the material seems to collect around the nozzle and then get deposited in some random location.
Still need to clean up and maybe re-route the wires and figure out where I want to put the RPi that's running Octoprint.
Maybe my next upgrade down the road will be to turn it into a 'cube', make it wider and upgrade the build plate to 300mm x 300mm, instead of the 300mm x 230mm that it is now.
Edited 1 time(s). Last edit at 11/19/2018 08:56PM by Cougar281.
