heated bed heats indefinitely
Posted by Wrestler99
April 26, 2018 05:34PM
While using manual control the heated bed and extruder heat only to the temperature I tell them to. After slicing an object and hitting print, the bed heats up to the desired temp, 55 c, and just keeps going past till I get an error message around 115 degrees.
It does not matter if I type in a different value for the bed temp or use the temp slider to change it, the bed continues to heat.
My setup: Prusa i3, Repetier host, Arduino Mega w/ ramps
open | download - Configuration.h.txt (133 KB)
Re: heated bed heats indefinitely
April 27, 2018 02:27AM
Did you check the MOSfet area on RAMPS for bad solder jobs and the like?
What if you pause the print, change temp, wait and resume?
April 27, 2018 04:22AM
strange that it works ok manually, can you post the 1st 50 lines of your sliced G-code.
April 27, 2018 03:27PM
Here's the first 50 lines
open | download - First50linesGcode.txt (1.5 KB)
April 27, 2018 04:10PM
M190 S115 ; set bed temperature and wait for it to be reached
This is trying to heat the bed to 115 C and is probably timing out,giving the error.
Edited 1 time(s). Last edit at 04/27/2018 04:12PM by obewan.
April 27, 2018 05:18PM
obewan
Good Catch " OBEWAN "
May 07, 2018 04:30PM
Hey I got it figured out and working. Thank you for your help
May 07, 2018 04:31PM
Hey you were right! Thank you for the help!
