Re: Z axis May 04, 2018 08:33PM |
RepRot
With the Ramps board I am using, there are only 5 stepper drivers, normally 3 for XYZ axis and 2 for extruders (E0 & E1).
What happens you use the second extruder for the second Z axis, thus you can only have one extruder.
I have the Z2 pins setup ( Dir/step/enable) set the same as the E1.
Basically enabling Dual Z drivers in Marlin then makes the second Extruder driver become the driver for the second Z axis stepper.
Re: Z axis May 04, 2018 11:12PM |
Re: Z axis May 05, 2018 06:36PM |
Re: Z axis May 05, 2018 08:15PM |
Re: Z axis May 05, 2018 09:38PM |
Re: Z axis May 06, 2018 06:22PM |
Re: Z axis May 06, 2018 08:01PM |
erniehatt
Having problems with the Z axis, one side seems to be either running fast , or the other slow. I lift it up 100mm and one side is perfect but the other one reads about 5mm more.
Not sure whats up here, is it possible to use the E1 driver to run them separately, and will it work.?
Thanks
Re: Z axis May 06, 2018 09:46PM |
Re: Z axis May 06, 2018 11:32PM |
Re: Z axis May 07, 2018 11:00AM |
Re: Z axis May 07, 2018 04:48PM |
ayuda problema con flsun i3 pusa February 23, 2019 01:07PM |
