Editing files on Arduino and Ramps 1.4 boards.
Posted by dlw
dlw
May 10, 2018 09:17PM
As the title says, how can the files on the boards be upload to a PC, then edited?
dlw
Re: Editing files on Arduino and Ramps 1.4 boards.
May 10, 2018 09:37PM
you cannot take the running code on the controller and turn it back into source.
This is akin to trying to remove the raw ingredient from a cake
You need the original source code, or just start a fresh with latest firmware.
dlw
May 11, 2018 11:18AM
Thanks for replying.
OK, the post was not worded correctly.
How can the Ramps 1.4 firmware be uploaded to a PC? I did this a couple of years ago before getting the Tronxy.
dlw
May 12, 2018 02:49AM
You can only read out the eeprom settings via pronterface or other terminal. That will allow you to copy/paste the most important parameters into a .txt file.
The command ( IIRC) is M503.
