Leadscrew upgrade May 18, 2018 08:07AM |
Re: Leadscrew upgrade May 18, 2018 09:34AM |
Re: Leadscrew upgrade May 18, 2018 09:39AM |
Roberts_Clif
I purchased a 3D Printer with theT8-8 lead screws, and found that if you have any device close to the 3D Printer the makes a vibration the Z-Axis of the T8-8 will turn while printer is Off.
I upgraded to a T8-2 ( 8mm and only 2 mm Rise per revelation)
This is a video of a T8-8 lead screw, you will see that just gravity will cause the nut to fall.
T8-8 Lead-screw Drop with Gravity
[youtu.be]
Re: Leadscrew upgrade May 18, 2018 09:47AM |
Re: Leadscrew upgrade May 18, 2018 09:52AM |
Re: Leadscrew upgrade May 18, 2018 01:28PM |
Re: Leadscrew upgrade May 21, 2018 09:07AM |
Re: Leadscrew upgrade May 22, 2018 03:42AM |
Make sure the couplers between the lead screws and steppers are installed correctly (the motor shaft and lead screw should only be inserted enough for the set screws to grab)
Re: Leadscrew upgrade May 22, 2018 03:46AM |
o_lampe
I've placed a 4.5mm steelball between stepper shaft and leadscrew ( both are touching the ball ). That way the weight and inertia of the X-carrier can't compress the coupler, but it can still flex.
Re: Leadscrew upgrade May 22, 2018 08:02AM |
JoeK1973
I'd like to reduce Z-wobble (which is what I think I'm getting - visible horizontal ripples every 1mm or so (actually about 1.25mm which is the pitch of the threaded rod perhaps?)
Joe
Re: Leadscrew upgrade May 22, 2018 08:36AM |
Re: Leadscrew upgrade May 22, 2018 04:54PM |
Re: Leadscrew upgrade May 22, 2018 05:38PM |
Re: Leadscrew upgrade May 22, 2018 09:00PM |
Re: Leadscrew upgrade May 23, 2018 02:53AM |
BrianRosenthal
o_lampe
While I like the idea, what issues does coupler flex cause on the z axis?
