Have an issue with my Ender 3 bed. I can't level it no matter what I do and I've been at it for days now.
I've bought numerous sheets of glass and mirrors from a local supplier and when the aluminum heat bed is loose (no tension in springs) or removed from the y carriage the glass or mirror sits fine, but go to level or tram it to the nozzle in the four corners and the glass or mirror just rocks due to two
diagonals being higher the then the rest, yet my nozzle is positioned correctly. If i secure the sheet with bulldog clips i eventually run out of adjustment going round the four corners. I've tried obiviously glass and mirrors to flatten it, used 0.5 thermal pads, taken apart they carriage even drilled the holes
larger in the y carriage in case they weren't drilled correctly from the factory and was causing it to bulge. Any one have any suggestion because at the moment this it just a big deadweight.
