Getting Homing working properly
Posted by lorenjz
August 04, 2018 05:15PM
Hello,
I purchased a Einsy Rambo a while back and I've struggled to get it working. The most recent development was that I've been able to get the X & Y axis to move manually without any issues, but when I attempt to home the x axis the motor just resonates. I've made several adjustments to homing feedrates from 300 down to 200mm/m to 100mm/m and up as high as 350mm/m with out any perceived change in the resonance. Attached is my config file.
Any help would be greatly appreciated.
Loren
open | download - Configuration.h (68 KB)
Re: Getting Homing working properly
August 05, 2018 05:11AM
First thing i would try is setting
#define DEFAULT_MAX_FEEDRATE { 200, 200, 2, 22 }
After uploading then send M502 followed by M500 to update te values in the eeprom
August 06, 2018 04:43PM
@obewan, thanks for the suggestion but after changing the settings as you recommended, there was no change.
