bad printing Layer Shifting or Misalignment
Posted by Blisk
August 09, 2018 07:04AM
This is second print and it is the same don't know what happend but printer start to print a fev mm to left. (Layer Shifting or Misalignment)
On second print it start to print after a while fev mm to back of Y.
Any idead why this is happening?
Belts are ok and tight, what else can be?
I have upgraded firwmare to bugfix 1.1.x
Edited 1 time(s). Last edit at 08/09/2018 09:02AM by Blisk.
Re: bad printing Layer Shifting or Misalignment
September 25, 2018 03:13PM
Layer misalignment is generally caused by missed steps. There are a few common causes:
- Stepper driver adjusted too low
- Belt too loose on stepper gear.
- Extruder nozzle hitting the object while printing. (part lifting/curling)
- Interference in motion of the X or Y carriages.
- Attempting to print outside the physical X/Y limits (switch engaging)
- Error in gcode (uncommon)
Hope this info helps!
-David
Find me online at:
Thingiverse
Instructables.com
LinkedIn
Facebook
Check out my FolgerTech Prusa i3 (plexi) at MindRealm.net
September 28, 2018 08:22AM
Also anything jamming the movement. Stray end of the belt or a wire.
Also the drive gear on the motor slipping.
September 28, 2018 09:54AM
I have changed stepper drivers now it works OK
