Prusa i3 reboots (SD card print)
Posted by seventhsky
August 30, 2018 05:52AM
Hi there,
I have a Prusa i3 Hephestos and the printer was working fine for years. From one day to the other, I have the following issue.
I still can:
- move to the home position
- level the plate
- print objects via USB (!!!)
BUT I can not print any longer from the SD card. As soon as I select the .gcode-file, the Prusa reboots! Yes, not funny.
I have:
… formatted the SD card
… tried another SD card
… tried several other .gcodes-files
… up- and downgraded the firmware
But all without any luck. Do I have a power supply issue or defect display-card-unit? Any other ideas?
Many Thanks!
Re: Prusa i3 reboots (SD card print)
August 30, 2018 06:58AM
Sounds like Atmegas 5V onboard regulator gave up. You can use a 1A USB phone charger, if you don't want to connect it to your PC permanently.
August 30, 2018 07:20AM
Thanks! Where is this regulator located (RAMPS 1.4 or LCD-unit)? So you're telling me that when I connect a 1A USB phone charger (and power supply) I could print from the SD card again?
August 31, 2018 12:41AM
Does that answer your question? The LCD is fed by the onboard regulator and some graphic LCDs are known to draw to much current. Some older SD-cards also have this problem.
August 31, 2018 04:26AM
The 5 volt regulator is on the arduino board
September 02, 2018 06:47AM
It was the external power adapter/device (12V 8.0A)… replaced and works like a charm again… thanks!
