Heating failed 220 degree
October 04, 2018 09:14AM
i have a 3d printer but when i heated hotend and printed 3d parts while hotend reach 220 degree i take a error thats mean heating failed killed what is reason that error
Re: Heating failed 220 degree
October 04, 2018 12:11PM
Probably because that's the max temperature set in your firmware
Prusa I2
Gen7-ARM 2.0 / Teacup
Genuine J-Head Mk V-BV
Hypercube
RAMPS 1.4 / Marlin
E3D V6
Piper 1 Version 2
E3D V6
MPCNC
RAMPS 1.4/ Marlin
October 05, 2018 12:42AM
If you are using a non standard hotend with a more powerful heater element, you have to run the PID tuning command. Also see M301, how to set the new found parameters in Marlin.
October 05, 2018 04:37AM
Thanks for comment.i will change pid tuning on the marl in isnt it?
error printer set into dry run mode until restart
December 29, 2018 01:05PM
salve bella gente,
il mio rep rap prusa i3 mi da il seguente avviso error printer set into dry run mode untile restart,cioe quando connetto prima mi fa vedere che la temperatura della sonda e a 333 gradi e il piano a 24 poi sparice,passa a t def 0 e def 0.qualcuno sa qualcosa al proposito? qualcuno mi sa dire dove sono i termostati caso mai per verificare se sono difettosi ? grazie a tutti
