Prusa i3 XL: J-Head loosening and how to tighten it
Posted by kjakobczyk
November 01, 2018 06:30AM
Hello,
I had to replace J-Head in my home-made Prusa i3 XL. I've bought this one with an additional fan. The problem I'm facing right now is that rectangular chamber holding the 0,5mm nozzle is loosening when I head up the print head. Even if I tighten it up when the head is cold, when it reaches 220C it is loose what have negative effects on the leveling. During printout, the chamber may turn freely what causes the head to lower its position. Do you have some solution for this issue?
Best regards,
Chris.
Re: Prusa i3 XL: J-Head loosening and how to tighten it
November 01, 2018 07:09AM
most hot ends should be tightened when hot.
