Prusa MK3 trapezoidal nuts?
Posted by siblues
January 06, 2019 06:32PM
I just wanted to see if anyone would be kind enough to specify the bolt hole spacing on the original MK3 nuts?I am under the impression they are not the same as all of the knock off brass nuts floating around online.I can't seem to find any online suppliers for those nuts specifically they tend to list all the MK series together.I am trying to use a few thingiverse files for the MK3 on a custom built P3Steel that I have with no luck.The only thing that has me tied up is a set of these nuts.
Re: Prusa MK3 trapezoidal nuts?
January 06, 2019 09:25PM
measured 19mm, checked with scad which also says 19mm
from x-end.scad
// Screw holes for TR nut
    %translate(v=[0,-17, 0]) rotate([0, 0, -135]) translate([0, 9.5, -4]) cylinder(h = 19, r = 1.65, $fn=50);
    %translate(v=[0,-17, 0]) rotate([0, 0, -135]) translate([0, -9.5, -4]) cylinder(h = 19, r = 1.65, $fn=50);
ie -9.5 to 9.5 19mm.
January 06, 2019 09:39PM
Thanks for the quick reply Dust
