Prusa i3 Y axis occasionally gets stuck April 04, 2019 11:20AM |
Re: Prusa i3 Y axis occasionally gets stuck April 04, 2019 04:42PM |
Re: Prusa i3 Y axis occasionally gets stuck April 04, 2019 07:05PM |
Re: Prusa i3 Y axis occasionally gets stuck April 05, 2019 01:44PM |
Re: Prusa i3 Y axis occasionally gets stuck April 09, 2019 06:01PM |
papergeek
I started another print this morning which was not covering a huge amount of area, and this time it got stuck on an X-axis movement and became skewed.
My strongest suspicion is that either the drivers or other regulator components on the RAMPS board are failing. I was not expecting a failure so did not have temperature measurement running but all of my motors were too hot to touch when I cancelled the print.
A replacement RAMPS 1.6 board was fairly cheap so I'm going to try that. This rev is also supposed to handle more current than the RAMPS 1.4. At worst I'll be out $10 and will have an extra RAMPS board
Re: Prusa i3 Y axis occasionally gets stuck May 01, 2019 06:02AM |
