Z Axis Direction Challenge July 01, 2019 12:29PM |
Re: Z Axis Direction Challenge July 01, 2019 02:17PM |
Re: Z Axis Direction Challenge July 01, 2019 09:21PM |
The first thing I did with my 3D Printer was to add A power Switch. This way I could turn it off before something broke.Quote
G3056
We have built a Tevo Tarantula.
The printer is setup, and the only problem we had while starting up was my Z axis that broke as it forced the extruder into the bed.
G3056
We have tried a couple of prints, but have not gotten past the first layer or two. The axes all home correctly and the print starts well. at the second layer the printer starts dragging the extruder through the plastic.
It seems that the axis turns correctly when homing, but then inverts direction when it starts printing, or tried to print to below the bed level. If I loosen the lead screw and turn the thread in the correct direction when it is supposed to raise, We get a poor 20mm test print, (at least a couple of layers) but it works... The stepper keeps on stepping in the wrong direction though...
