Hictop 3dp-11 Shutting down when heated bed is turned on September 13, 2019 12:27PM |
Re: Hictop 3dp-11 Shutting down when heated bed is turned on September 13, 2019 01:26PM |
Re: Hictop 3dp-11 Shutting down when heated bed is turned on September 13, 2019 02:30PM |
Re: Hictop 3dp-11 Shutting down when heated bed is turned on September 13, 2019 09:09PM |
Re: Hictop 3dp-11 Shutting down when heated bed is turned on November 20, 2019 01:41AM |
Re: Hictop 3dp-11 Shutting down when heated bed is turned on November 20, 2019 12:04PM |
Re: Hictop 3dp-11 Shutting down when heated bed is turned on November 22, 2019 12:14AM |
Re: Hictop 3dp-11 Shutting down when heated bed is turned on November 22, 2019 10:56AM |
Re: Hictop 3dp-11 Shutting down when heated bed is turned on November 24, 2019 04:52AM |
Re: Hictop 3dp-11 Shutting down when heated bed is turned on November 24, 2019 10:34AM |
Izzie
Cliff if I flash the firmware that you kindly supplied me for the old controller to the new controller will I have to make modifications to the configuration file so that the SD card slot works on the new controller or will I just be able to use the one on the screen as normal ?
Hope that made sense.
Re: Hictop 3dp-11 Shutting down when heated bed is turned on November 24, 2019 01:05PM |
Re: Hictop 3dp-11 Shutting down when heated bed is turned on November 24, 2019 03:14PM |
Izzie
Is there any chance that you could share the marlin firmware that you use as I don't mind what SD slot I have to use i just didn't want to flash the old controller firmware that you supplied me and the SD slot wouldn't work.
Re: Hictop 3dp-11 Shutting down when heated bed is turned on November 25, 2019 07:47AM |
Note: It is new version HICTOP main board, it is compatible with 3DP08, 11, 12, 16, 17, 18 etc, but when you use this one you will need to insert the SD card into the card slot on the main board instead of the one on the LCD
Re: Hictop 3dp-11 Shutting down when heated bed is turned on November 29, 2019 11:58AM |
Re: Hictop 3dp-11 Shutting down when heated bed is turned on November 29, 2019 08:10PM |
Re: Hictop 3dp-11 Shutting down when heated bed is turned on December 01, 2019 03:48AM |
Re: Hictop 3dp-11 Shutting down when heated bed is turned on December 01, 2019 09:01AM |
Re: Hictop 3dp-11 Shutting down when heated bed is turned on December 02, 2019 01:56AM |
Re: Hictop 3dp-11 Shutting down when heated bed is turned on December 02, 2019 10:27AM |
