Best printable Direct Drive extruder for DIY i3 MK2S? September 05, 2020 05:46AM |
Admin Registered: 13 years ago Posts: 3,096 |
Re: Best printable Direct Drive extruder for DIY i3 MK2S? September 06, 2020 03:30AM |
Admin Registered: 15 years ago Posts: 7,321 |
Re: Best printable Direct Drive extruder for DIY i3 MK2S? September 09, 2020 08:28AM |
Dust
Have you seen my MK2 power supply case? [www.thingiverse.com] Its the prusa one but in scad so you can edit it to fit your supply (presuming its a rectangle)
Yes that filament runout sensor works on any 5v controller.
The standard mk3s extruder works well...
Check the length of that runour sensor cable. A lot of these clones parts are being supplied with 160mm cables, but needs longer in real mk3s's. 175mm. But yours is custom.. so who knows...
so I'll be using my own. Because I'm also using a 3-pin power cord and use a special connector for that with a switch and fuse. Before drawing that out I had to redesign the entire frame in Fusion360 because I couldn't find the correct files anywhere except when digging deep I found some DXF.|
Re: Best printable Direct Drive extruder for DIY i3 MK2S? September 18, 2020 11:07AM |
Dust
