Hi
Trying to calibrate the extruder on a G3D but I'm clearly doing something wrong.
I changed the value of DEFAULT_AXIS_STEPS_PER_UNIT in the configuration.h file (approx line 760ish) to the below
#define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, 2000, 785 }
However when I issue the M503 command to the printer the M92 is still reporting an old value
M92 X80.00 Y80.00 Z2000.00 E746.00
Thinking I hadn't uploaded correctly to the Arduino Mega I changed the STRING_CONFIG_H_AUTHOR value with a number 001, 002, 003 and so for each upload.
I can confirm the upload is working fine, but the extruder value isn't changing.
What am I doing wrong?
Is DEFAULT_AXIS_STEPS_PER_UNIT the correct #define to change?
It seemed to be, when I changed the X, Y and Z with no problems.
Many thanks in advance.
