Hello, my name is Alex, I wanted to ask for help with the configuration of Marlin 2.0.7.2, build a Prusa I3 Mk3s clone, with SKR 1.4 turbo + TMC2130 SPI sensorless (1 driver for each X, Y, Z and E axis), (2 motors on axis Z with only 1 driver), (X_STALL_SENSITIVITY 12, Y_STALL_SENSITIVITY 10) (Probe with many STALL_SENSITIVITY values and that value is the most useful)
I have the following problems:
1-From the pronterface or the LCD screen I can only do a successful homing, the second one fails, the motors only move very little and the home is wrong
2- Step loss problems (configured with 800 mA each axis, the motors are 1.4 amp, 5.3 kg x cm torque). This is random, sometimes at the beginning, sometimes within 3 or 4 hours of printing.
3- Z wooble problem that did not appear with the same equipment and A4988 drivers on all axes
4. Problems with adhesion to the hot bed (the bed works perfectly, I have the impression that the layer fan is too powerful, so I reduced the speed to 50%, with less warping, but there is still warping. If not Layer fan is turned on there is no warping
What drives me the most crazy are points 1, 2 and 3 (I think 4 can be corrected when I find the right value for the layer fan.
Can anybody help me?
