I've been struggling with this for a few days and just can't figure it out. I had a really old build of Marlin V1 from 2014 and I wanted to replace the problematic servo probe with an inductive probe. Printer worked fine before the upgrade besides the inconsistent servo probe. I added the (blue tip lj12a3-4-z/bx) inductive switch with a voltage divider and m119 shows it triggering as expected. I used all the old settings from the old configuration file in 1.1.9. XY homes correctly but when homing Z it goes up instead of down. Moving Z up and down in pronterface moves in the correct direction. I've also tried inverting the z min endstop and unplugged the sensor, verified m119 showed as open and homing still goes up instead of down. I attempted to compile my old marlin version but can't because I'm missing an old u8g library and can't seem to tip it. Inverting the z axis does make it home in the downward direction, but regular movements are reversed. If I swap arduino's to my old marlin version, it homes just fine, so I know it's a firmware issue, but I can't figure it out. I'm hoping someone here has some suggestions.
I've tried enabling and disabling the Z pullups, but doesn't seem to make a difference.
This seems to be a common issue with most people saying to check the endstop invert parameters, but that isn't helping or missing something very obvious. I verified with m119 before homing z and it shows as open, so it isn't triggered before homing. I manually touch the bed with the probe while it's homing in the wrong direction and it does stop the z axis. it's just going in the wrong direction.
This is on a i3 rework printer with a ramps 1.4 board.
This is the relevant config I have in 1.1.9 and matches my old 1.1 version besides the additional defines for the fixed probe which didn't exist in the old version. I have attached my full configuration.h file as well.
#define Z_MIN_ENDSTOP_INVERTING true
#define Z_MIN_PROBE_ENDSTOP_INVERTING true
#define Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN
#define FIX_MOUNTED_PROBE
#define INVERT_X_DIR true
#define INVERT_Y_DIR true
#define INVERT_Z_DIR false
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
Let me know if you need anymore info, I've been pulling my hair trying to get this to work.
Thanks!
