Geeetech PI3B Part fan slows to a stop
Posted by RolyB
February 19, 2023 04:47AM
I have a Geeetech PI3 ProB (GT2560 RevA+) with Marlin 2.1.2 installed and a part cooling fan added.
The part fan "Hunts" speeding up and slowing down and then gradually slows to a stop while printing following the first M106 command.
Running the fan via Manual Control in Repetier-Host works as expected.
I have written a short script which starts the fan and simultaneously moves the X, Y and Z axis.
If I run this script from Repetier-Host the fan runs continuously whilst moving the axis as it should.
Has anyone else experienced similar behaviour?
Attached are the configuration files being used. Lines commented with RHB are my amendments.
Thanks in advance for help/suggestions.
Roland
open | download - Configuration.h (124.8 KB)
open | download - Configuration_adv.h (173.3 KB)
Re: Geeetech PI3B Part fan slows to a stop
February 19, 2023 06:59PM
There was an issue with the base PWM frequency being set to high on atmel mega2560 in that release.
When turned on full PWM is DC so no frequency issues
Use bugfix 2.1.x or release 2.1.1
February 21, 2023 05:36AM
Thanks for your help Dust.
Unfortunately both 2.1.1 and 2.1.x show the same issues.
I have also noticed the fan is shown as running at 93% in Manual Control though it has stopped.
If I cancel the print the fan starts running when I home the extruder and has to be turned off manually
Roland
February 21, 2023 12:00PM
I have now tried release 2.0.7.2 (as it was on my machine) with exactly the same result :-(
April 27, 2023 04:46AM
Just wiping the egg off my face here :-)
Turns out there was an internal fault on the fan connection which didn't show up when moving the print head in tests.
Moral being test the power supply.
Thanks
R
