To save space, I created a new spool on top installation, with spool support done with two skate bearings (608).
This doesn't work any better than the former Fisher spool on top (on spigot): [
forums.reprap.org], but is more compact and more elegant.
It does accept spool with 50mm + hole (with a ring) or 30mm + hole (without ring), but spool with 25mm holes (say small Taulman spools) cannot be installed.
While the support is only 130mm diameter, it is fairly stable with spool of 200mm diameter.
Brake is required for good unwinding as bearings makes the rotation too easy and that end up in crossed loops and knots.
If printed in PETG or ABS, the spool brake may look a bit weak but it works ok (supplied files will give a stronger brake than my own installation).
There are two "pins" underneath the brake which maintain it firmly in position. 2 holes diameter 4mm spaced 12mm shall be drilled in top plate for these pins.
As spool holes are generally larger than 50mm, the spool is never perfectly centered, but this have no effect on the operation.
BOM list :
*2 608ZZ (or 608RS) bearings
*1 M8x40 screw hex head, fully threaded
*2 M8 hex nuts
*1 M8 butterfly nut (could use an hex nut instead)
*4or 5 M8 small washers
*1 wood screw 3x10 or bolt M3x15 (for the brake)
Printed parts:
*Spool support
*Ring for 50mm spool
*Brake
Bearings are separated by an M8 nut + 2 washers.
Depending your washer thickness, you may have to set one or two washers below the bottom nut to give space for the spool brake.
Files will be supplied in next message
Fisher delta
This is a relatively large part (diameter 130mm) to print on the Fisher Delta and I experienced skipping steps at first print.
Top print it, you need :
*A reasonnably flat bed and properly calibrated machine
*To reduce the travel speed (I used 180 mm/s)
The last SD image of Fisher Delta have increased the travel speed from 200 mm/s to 250 mm/s. That may work for small parts, but with the geometry of the Fisher and its short arms, that is not ok for large parts. If still experiencing lost steps after reducing speed, you may reduce a bit the accelerations (G-Code M201 [
reprap.org])
Edited 2 time(s). Last edit at 09/26/2015 08:03PM by PRZ.
Pierre
- Safety [reprap.org]
- Embedded help system for Duet and RepRap Firmware [forums.reprap.org]
- Enclosed delta printers Lily [rouzeau.net] and Lily Big [rouzeau.net]
- OpenScad delta printer simulator [github.com]
- 3D printing on my site [www.rouzeau.net]
