RepRapPro's new printer kit (off-topic) May 22, 2015 11:56AM |
Re: RepRapPro's new printer kit (off-topic) May 22, 2015 12:52PM |
Re: RepRapPro's new printer kit (off-topic) May 22, 2015 02:01PM |
droftarts
I see Sally in the background... I hope you talked to her and JM! They are both there.
droftarts
They leave me behind nowadays, I clearly can't be trusted to talk to customers...
Re: RepRapPro's new printer kit (off-topic) May 22, 2015 02:06PM |
Re: RepRapPro's new printer kit (off-topic) May 22, 2015 02:57PM |
Re: RepRapPro's new printer kit (off-topic) May 22, 2015 03:12PM |
Re: RepRapPro's new printer kit (off-topic) May 22, 2015 03:21PM |
Re: RepRapPro's new printer kit (off-topic) May 22, 2015 04:06PM |
auser
could anybody give some indication on the printbed? Is it heated? or covered with a special surface finish?
RRP website does not mention a heat-bed (from my reading)
Re: RepRapPro's new printer kit (off-topic) May 22, 2015 04:13PM |
Re: RepRapPro's new printer kit (off-topic) May 23, 2015 06:24PM |
Re: RepRapPro's new printer kit (off-topic) May 23, 2015 06:47PM |
Re: RepRapPro's new printer kit (off-topic) May 24, 2015 04:12AM |
Re: RepRapPro's new printer kit (off-topic) May 24, 2015 04:18AM |
Re: RepRapPro's new printer kit (off-topic) May 24, 2015 04:54AM |
Re: RepRapPro's new printer kit (off-topic) May 24, 2015 07:52AM |
droftarts
As far as I know, it will be supplied with the same 19V 6.3A PSU as the Huxley Duo, which has a 5 ohm, 140mm x 140mm heated bed, so it's possible a heated bed upgrade will be offered in the future. But it probably means designing one specifically for this machine, or changing the PSU to match an existing bed.
Re: RepRapPro's new printer kit (off-topic) May 24, 2015 08:19AM |
Re: RepRapPro's new printer kit (off-topic) May 24, 2015 08:46AM |
Re: RepRapPro's new printer kit (off-topic) May 24, 2015 09:01AM |
Re: RepRapPro's new printer kit (off-topic) May 24, 2015 09:06AM |
Re: RepRapPro's new printer kit (off-topic) May 24, 2015 11:28AM |
Re: RepRapPro's new printer kit (off-topic) May 24, 2015 11:42AM |
Re: RepRapPro's new printer kit (off-topic) May 24, 2015 02:05PM |
Re: RepRapPro's new printer kit (off-topic) May 24, 2015 04:01PM |
Re: RepRapPro's new printer kit (off-topic) May 25, 2015 03:27AM |
Re: RepRapPro's new printer kit (off-topic) May 25, 2015 04:35AM |
7sumantb
DC,
Do let us know how your 300x480 Kossel works out.. My experience with the bigger build printers is that the frame needs to be heavy and stable, because vibrations etc multiply and this affects machine movements, and print quality. So, I am ok with the smaller foot-print machine for doing my small parts - at the end print quality is important (to us).
Re: RepRapPro's new printer kit (off-topic) May 25, 2015 08:06AM |
Re: RepRapPro's new printer kit (off-topic) May 25, 2015 08:25AM |
Re: RepRapPro's new printer kit (off-topic) May 25, 2015 08:46AM |
